RADEON LE and XP
racinjimy
73
I am having huge issues with my radeon le card (flashed with radeon 32mb ddr bios)
Not only have I had to up the I/O voltage but half the time it only boots in VGA mode. Works fine in win98.
I am using the XP drivers on the CD, this is my second XP install and after loading all new SBlive and Radeon drivers the problem was not fixed on the first install.
Any suggestions?
Thanks,
Jimbo
dual boot 98/xp
Abit KT7a-R (bios 64 2.0.1024 latest and greatest)
2x ibm 40gb deskstar
radeon le flashed to ddr bios
sblive 5.1
2x NIC
pioneer 12xslot load dvd
plextor 12/10/32a
really fast cable modem (grin)
John
Moderator Emeritus<br>Elite Member
4
<< (flashed with radeon 32mb ddr bios) >>
Every think that could be the root of your problems?
racinjimy
73
Sure, but it has worked in win98 for 6 months with no problem, even overclocked to 185mHz......................
S0me1X
1,480
I ran my Radeon LE (also flashed to DDR) in XP without any problems. Perhaps you didn't do a clean install of Windows XP.
racinjimy
73
Thanks for the reply........
I installed XP on a freshly formated NTFS partition both times.
What MB are you running SOme1X?
Jimmer
RC7
521
I am running my Radeon LE fine in WinXP Pro with the XP driver from rage3d.com. I think that could solve your problem.
