- May 24, 2000
- 3,147
- 0
- 0
I had my nephews over on the holiday and they were playing Star Wars Pod Racer on my computer. I have the Radeon LE 32DDR in my PC and it has always worked well and given a good picture with no noticable defects or artifacts. I had been running at it's stock 148 mhz setting but decided recently up install power strip and OC it. I decided to go for a modest OC and set the card for 166 mhz. Many/most do 188 mhz or better.
When we were playing Pod Racer, I noticed the back ground was bleeding through in a area in the lower screen, so that through a band, instead of the Pod, you saw the back ground. I have never seen this before today.
I haven't played the game for a while. Here is what I've don't to my system since then: Replaced the motherboard and CPU, OC'd the CPU from 1.0 ghz to 1.33 ghz and OC'd the Video card from 148 to 166 mhz. I have gotten no errors since OCing the CPU.
Any ideas as to what was causing the back ground to blead through the Pod in Pod Racer?
