Whats the deal???? I just got my new comp built and installed my Radeon AIW. Now my image is almost like triple vision. It is clear representations of everything. Its kinda hard to describe. Almost like ghosting. How do I fix this?? It is drivin me nuts.
im guessing the connection from monitor to video card is bad (or bad cable) see if the problem is monitor or videocard by trying the monitor on a different pc. isolate the problem and give us a better discription, it's hard to help with what u said so far.
I think it is a prob with the vid card not synching up with the monitor. Wait...I jsut found teh prob. I ahve the monitor on a VGA extension cable and it seems to be too long
