radeon hd4850 fan speed?
ab11
42
is it necessary/recommended to manually increase the fan speed for my new hd4850?
(i have no plans to OC...)
thank you
octopus41092
1,840
If you're having crashing or heat related issues then yes. Even still I would turn it up a little bit just to keep it cooler since that would increase the lifetime of it anyways. You don't have to turn it up to 100% or anything just whatever noise level your fine with. I find that most people agree on around 40%
User5
215
I would increase it no matter what.
40 is the magic number. Theres NO difference in noise from the stock setting going to 40, since it seems like 40 blends in with the average case fan.. and you are looking at a good 20c drop in temps, idle and load.
