Radeon hd 2600 pro?
sem1966
26
Is ati hd 2600 pro made by versiontek any good?. I never have hd video card before, please give some idea.
tvdang7
2,242
versiontek? or visiontek .should be good. no problems ive heard of yet. but is this for light gaming?
qbfx
240
Originally posted by: sem1966
Thanks guys for input, i using just play movies go online and very light gaming.
Then you should be ok. Even low-end ATi's like the HD2600pro have UVD (universal video decoder) which utilizes the GPU to decode video (especially useful if you wanna play HD content on a slower CPU) ...
johnsonbrewer
I just installed one last night and its super for my needs. Light gaming and HD decoding, surfing. It is the AGP version but should be similar at PCI-E. On sale at BB for $99 last week. It took awhile for the drivers to get straightened out but they are now, just make sure you have the latest ones -- 8.45 for AGP and 8.1 ( I believe ) for PCI-E.
Auric
9,591
8.45 refers to the driver version while 8.1 is the package version (Catalyst) including control software and so on.
I have found driver 8.41 is sadly the only viable option -for AGP on XP, at least. The next release gibbled 3D and the next two including current 8.45 are incapable of DxVA on a secondary display. Full-screen mirroring by VMR7 Windowed still works but if the player must be on the secondary to show there (as with BD/HD DVD) then DxVA is inactive. Scuttlebutt is that Catalyst 8.2 (driver 8.46?) is due shortly (perhaps this week) so I hope this defect is corrected.
Otherwise, the 2600 Pro is ideal for motion video and not too shabby for light gaming although the XT would be a better choice in that regard. The fan runs too fast by default so needs third-party software or some DIY hardware fix, in my opine.
Foxery
1,709
Actually, no - the UVD feature was left out of the 2000 series. The 3000 series has it.
If you're running a somewhat recent Core2 or Athlon X2 system, you won't miss it, though.
Auric
9,591
Misinformed. Only the high-end 2900 did not have UVD because 1) it's development began first 2) the GPU was already costly enough due to complexity & size 3) its shader power plus presumed matching with a high-end CPU could manage decode (although of course at great cost in power consumption and all related issues).
