S SendTrash Platinum Member Apr 18, 2000 2,581 0 76 Jan 30, 2001 #1 Pls post the settings you use to record TV shows... I have no clue to what I should set mine... btw MPEG2 doesn't work for me.
J jinglingxl Golden Member Mar 3, 2000 1,184 0 0 Jan 30, 2001 #2 I set it at Mpeg2 352x240 NTSC 44,100 KHz, 16bit why doesnt the mpeg2 work for you
S SendTrash Platinum Member Apr 18, 2000 2,581 0 76 Jan 30, 2001 #3 I drop frames like mad in MPEG2... even though I have P3 800.. no clue about that
C CQuinn Golden Member May 31, 2000 1,656 0 0 Jan 30, 2001 #4 Try MPEG-1 and/or 22,000 KHz, 16bit. Or you can try dropping the bit rate down.
