whaz the memory core and the clock speed difference between the Radeon 9800 Tx and the 9800 Pro? is it worth going for the Pro right now. (an extra 8000 Rs.)how much differnce will it make in the bandwidth and in the working of gamed like doom3....
Personally, I think the extra money for the 9800 pro isn't worth it and the tx is a great value. I don't know the clock speeds for the tx though. And what currency is the Rs? The South African Rand?
The core can usually overclock very well but the memory is very limited (unless you happen to get a card with ram faster than is normally speced for your card like Sapphire would sometimes provide.).
The TX comes with 2.8NS memory according to some people over at rage3d so it should overclock really well! Should be able to reach ~350
