Radeon 9800 Pro
fightcancer
100
I'm thinking of upgrading the GPU in my Gigabyte GA 7ZXE mobo to a Radeon 9800 Pro. However, the 9800 is an 8X AGP card and my mobo only supports 1X, 2X, and 4X.
Will the 9800 run in my existing mobo?
Will the 9800 run slower in mine?
Thanks!
fightcancer
100
Thank you!
For the Radeon 9800 Pro:
1) Will there be a substantial difference between 128MB and 256MB of video RAM?
2) Which would you recommend:
a) a Sapphire Radeon 9800 Pro w/128MB, Open Box buy from NewEgg.com for $75 w/S&H, or
b) a Chiefmax Radeon 9800 Pro w/256MB, brand new retail from eBay (99.1% positive feedbacks) for $90 w/S&H?
Thanks again!
RiBeNtRoP
23
In that GPU, it is not very important the quantity of the RAM but the quality does ;) So, i will prefer option a) Sapphire
In my opinion, one of the best company for ATi GPU's is Sapphire, so, go on with that GPU, but you must know that that GPU does not support PS3.0
corkyg
Elite Member | Peripherals
27,370
240
Pixel shader 3.0 is not important unless you are a serious gamer.
PS3
RiBeNtRoP
23
Shader Model 3.0, Pixel Shader 3.0 ... everything related with effects in the latest games that you won't enjoy.
Sorry if you did not understand what i've said, it's just that english is a little bit difficult to me, i'm from spain :p
fightcancer
100
ty!
Hablas muy bién y lo entendí, pero no comprendí "PS3.0" hasta que uds. me lo explicaron. ¡Muchas gracias y feliz año nuevo!
