Radeon 9800 Pro clock speed going down
effee
Hi all, I did some OCing to benchmark my 3dmark05, I got 2400 and I'm on a A64 3200+ with a 9800pro 128..
anyway, after OCing it and benchmarking, i decided to revert it back to default clockspeed as i am on stock cooling. Anyway, I found that Radlinker put it as 378/336.5 for default instead of 378/338 which is default, what does this mean? Could my 9800pro have been damaged during that OC so the default mem clocks went lower? it wasnt a very long OC, about 6 mins or so for 3dmark05 to run..
No, your memory isn't damaged, this must be a bug in Radlinker, because if your memory was damaged Radlinker doesn't automatically chagne its default clocks to a safer number. And since you're not seeing artifacts at the high OC level then your stock clocks should be 100% safe, plus you only overclocked for 6 mins.
I see, thanks, I guess I was just paranoid about doing an OC on stock and must have clicked a lower value by mistake
