RockGuitarDude
Are they worth the money right now and do they overclock easily?
Wrong.Originally posted by: n0cmonkey
256MB of ram is supposed to be a waste, BTW.
The most noticeable addition is the Blue-LED light found in the card's heatsink-fan unit. This provides a blue-toned light, and is especially useful for those with high-end, windowed systems. In our testing, this provides adequate light for the entire bottom portion of the case, and is bright enough to be seen in normal lighting conditions. The heatsink itself is copper-based and provides a nice mix of cooling performance and eye-catching gold trim. Hercules matches this up with copper heatsinks for the memory modules, and the end result is a very attractive video card that also has a full copper-based cooling system.
Totally wrong. Those cards can be upgraded to a 9800 -XT simply by flashing the BIOS. 😉
edit: how'd that get in here? 😛
. . . anyway that Hercules 256/128MB RAM card with blue LED and copper RAM sinks should be an awesome o/cing card - IF you have $189. 😉 Q]
$100 extra for the ability to flash the card to an XT seems pretty useless to me, considdering a regular 128MB Pro can probably be overclocked to close to XT speeds anyway.
Unless you have lots of money to waste that is.
$100 more now. 😉
The 256MB ram version should be pretty cheap soon with not much of a premium over the regular 128MB ver. - in that case it's a good deal if you want the best of the old cards - at a bargain price - as the 9800xt is still ~$350.
I just got this one:
ATI RADEON 9800 PRO Video Card, 256MB DDR, 256-bit - $223 shipped from NewEgg
I know i kept talking about a x800 or 6800 . . . 😛
HOWEVER - THIS one can be simply FLASHED to a 9800 - XT
What made up my mind?
(other than i can have this one b4 Fri) 😀
Comparing the x800 to the 9800xt . . . my monitor's MAX refresh rate is 1280x960 @ 80hz (i prefer 1152x864 @ 85hz) . . .
not really THAT much difference for LESS than 1/2 the price of the new core GPUs . . . PLUS - in the FALL - i can still sell my "XT" for $175+ and get an NV45 or r480 . . . 😉
(if i still have the upgrade itch)
So i settled . . .
So i settled . . .
I dont understand the logic there. Even the article you mention says 256MB of ram is useless. Why would someone care about flashing a 256 9800 pro into a XT when they can overclock a 128 9800 pro into a 128MB XT.
The performance differences are minimal in regards to amount of ram, its all the speed of the ram and the core.
