Radeon 9800 np Image problems
monte84
59
I am having weird image problems with my card. In UT light blurs are replaced with strange textures, and in splinter cell(demjo version), when AA is enabled lights show through walls and are extremely bright. I have seen no know UT2k3, Unreal 2 errors like this. most probs in UT go away when AA and AF is disabled, same for Splinter Cell( which wont run AA when resolution is set to 1280*1024.
AMD Athlon 2700+
ANTEC 430 watt trupower PSU
Catalyst 3.6
DX9.0a
ASUS A7N8X
any help would be apreciated
THANKS!
McArra
3,295
Sprinter Cell has problems when AA is enabled with every card. I've never heard of the problem with both Unreal. I haven't got that problem with Unreal 2 at 1024x768 4xAA and 16xAF in my 9700p. Have you tried with cat 3.5? I don't think thats the problem but try it. Or try uninstalling drivers and installing the 3.6 again. Are you using DX9a? If not try it also. Good luck.
monte84
59
i am using DX 9.0a the only problem is in Unreal Tournament and Deuas Ex, when A A and perhaps AF is enabled. Is this a known issue with the 9800 series card? Uneal 2 uns fine, no glitches same with Unreal Tournament 2k3.
I have screen shots of the problem if that might help
Thanks
