It seems since I installed cat 4.2 the monitor goes into standby and the system hangs. So I tried going back to cat 3.10 after an uninstall of the 4.2s. But the problem followed. So I tried a system restore... no luck so I tried a safe mode uninstall and regedit with a safe mode manual install of a few of the archived versions. No luck. Occasionaly the vpu recover will make an attemp and send a report to ATI. The system has been rock solid stable for a year since I built it, now I'm stumped. Any help is welcome, Here are the specs.
Gigabyte GA-7VAX Rev 1.1 KT400 w/VIA Hyperion 4in14.51
Athlon XP2600+ @333 (not overclocked) w/Volcano 8 HSF
1 512mb stick GEIL PC3200 @Cas2.5 clk3 2t w/copper HS at Slot 1
OCSystem Radeon 9700pro w/ramsinks and blue orb. ver 1.0 (Ithink)
Catalyst 4.2 (7.97) w/control panel.
2 ea 30 gig Maxtor Diamond Max Plus 7200rpm 2mb cache with 2/2-20mm fans (IDE Master0)
Sony 52x CD Rom (IDE master 1)
Onboard AC97 5.1 sound (Realtek ALC650) w/update
Altec Lansing 5.1 Surround Speader System
Onboard LAN Realtek RTL8100BL w/update
Sylvania F97 19" Monitor @85 Hz 1020x768 32bit
Ascend Pipline 50 ISDN router on Dlink 650
WinxpHome 5.1.2600 SP1 Build 2600
