Radeon 9700 Pro HELP
JBird7986
230
Hey out there!
I was wondering if anyone could help me. I'm not sure when this first happened, but recently I've noticed a drop off in framerates on my 9700 Pro. I'm currently running the latest drivers (6.10) but where I used to get about 100fps on the HL2 Stress test in CS: Source, I'm now only getting about 68fps. Any ideas on what might have caused the drop off and how to fix it?
Slammy1
2,112
Check to make sure your fan is spinning OK. You might d/l ATITool to check temps.
JBird7986
230
I was checking CPU-Z when I noticed something funny...the graphics interface setting is grayed out. I then went to the ATI drivers window and checked SMARTGART. It says my AGP is off. I've tried turning it back on, but it won't work. AGP is enabled in my BIOS. Any thoughts?
evolucion8
2,867
Well, is weird, did you use Driver Cleaner before reinstall, there's some options in there that may delete some chipset drivers without your knowledge, I suggest you to uninstall the Display Driver completely, use driver cleaner in safe mode, then reboot and reinstall the Chipset Driver, reboot and then reinstall the Display Driver, if that doesn't work uninstall the Display driver and use the previous one, I had to do the same because I was having issues with the 6.10 also, it was unable to read my Temperature Sensor, and was freezing up in many games. That doesn't happen with the 6.9, we shall wait then to 6.11 to see any improvements though.
JBird7986
230
I got a slight FPS increase when I did that to about 71.1FPS...this is still about 30FPS lower than what I used to get...is it possible that there's something wrong with my BIOS that's interfering with my AGP?
JBird7986
230
Scratch that...just downgraded my BIOS and it did nothing...I'm stumped...anybody have any ideas?
JBird7986
230
OK...so I think I've figured out what's going on...for some reason, my card is reading as a PCI card. Anybody have any ideas why this might be and how to fix it?
Killrose
6,230
8
Did you download and use the full version driver which contains both Control Panel and Driver? Try re-installing only the Control Panel drivers if you did, if not, try a Driver set that contains both.
Avalon
7,571
178
Does your PCI to AGP bridge show up in your hardware device manager list?
Killrose
6,230
8
Another thought is you might have to re-load the Mboard chipset AGP gart drivers. Load only those if given a choice.
JBird7986
230
Success!!!! I installed an older AGP driver, and then upgraded to the current one from there and according to CPU-Z my AGP bus came back on-line this morning! The three month battle is over!
