Radeon 9700 Pro for 89.99
Yea, not seeing Pro anywhere in that description...
EDIT: Well it says it in one spot down near the bottom, "The ATI Radeon 9700 delivers robust graphics power. With record-setting fill rate and geometry processing power, Radeon 9700 Pro is the power user's choice for running the most demanding PC 3D games. "
But everywhere else, including the product number, shows a NP.
Thanks OP for the heads up.
With the price of some 9800 Pros dropping to the low $100s, and these being pulls (with warranty?) it would prob be better to pass.
check out the AIW version of the 9700 Pro, refurb'ed @ newegg for $100 shipped, better deal from a better seller, minus one vga output is all you're giving up, but the TV/video capture features of the card are the same as those on the x800xt AIW cards I believe (theater200 chip)
