Radeon 9700 PRo bios
Hanpan
4,812
I need the retail 9700 PRo bios file.
If anyone can hook me up it would be most appreciated.
Thanks.
Slappy00
1,820
4
Just Curious.... what did you do?
is there any way to export the file?
try third party manufacturers
Gigabyte, Sapphire, etc (they might have a BIOS that works)
Kazuo
145
The Radeon 9x00 BIOSes are available at http://home.mindspring.com/~warp11/ (which was linked to from the xbitlabs report).
Edit: Whoops. I am an idiot. They don't appear to have the retail 9700 Pro BIOS there. But they do say that the only difference between the 9700 Pro and the others is the one bit that's hacked (which basically means that the 9700 hacked BIOS is the 9700 Pro BIOS.
Hanpan
4,812
I need this for an experiment involing the radeon 9700tx
Yes you can use atiflash.exe to export the file.
I believe there are instructions on the page Kazou mentioned or you can pm for instructions.
