ATI says it needs a power connection to the Power Supply Unit. Could I just take the power connection from the Floppy Drive and insert it into the Radeon 9700 Pro instead? Is that an option?
Supposedly it will take a standard 4pin molex connection. Sounds like it has some hefty power requirements.
I'm waiting on the NV30 and I hope that it doesn't need that much power as well.
The connector on the card is made for a floppy connector, but I think the cards come with an adaptor, so you can use the larger connector made for hard drives and optical drives, too.
It's a standard floppy style connector on the 9700 card ATi packs a small cable that has an extra one.
In case you have run out floppy conectors or its not long enough to reach..... ATi 9700 Gear
On my 8500 DV card I just used my floppy drive connector since the PSU had a long length for it....
Plus my PSU had 3 floppy style connectors one on a short line 2 on the long lines....
