Radeon 9600XT Problem
RaGe420
I just installed a new Radeon 9600XT and it is turning the screen yellow after about 10-20 minutes.
I have updated to the newest drives, and also reistalled windows but still no luck.
Here is a pic so you can see what I am talking about.
could be overheating.
check if the fan is spinning and also the heatsink is flushed against the gpu.
my friend had the same prob with a 9600pro 256mb, he RMA'd it cuz nothing he did fixed it... not trying to scare you or anything, but if those 2 options dont help.. try going to the basic source... the card
Just got around to exchanging the card at the store I bought it from.
Came home plugged in it and have had no problems for over 6 hours now.
Looks like it had bad memory.
Thanks everyone for your help.
