RADEON 9600 Pro 256MB or GeForce FX 5600 Ultra 128MB?
Curto
43
Hi all,
I'm trying to decide what vid card to get for my second pc (I just sold the GF3 Ti200 that was in it ;)).
I'm down to these 2 cards (both ~$100) but I hear mixed feelings about both.
The other specs of the machine are:
Athlon XP 1600+ (1.4GHz)
512MB PC333 DDR
Asus A7V8X (KT400 chipset with onboard audio and ethernet)
16x DVDROM
80GB 7200rpm HDD
Right now my main pc is running a GF4 Ti4600 (Gainward Goldensample 750XP from memory... one of the VIVO/dual DVI cards)
512MB PC400 DDR
Asus A7N8X Deluxe (nforce2 chipset with onboard audio and dual ethernet and sata)
16x DVDROM
4xDVD-R
120GB 7200rpm HDD
Any suggestions? or is there another card around the $100 mark I should go for?
The second pc won't be used a lot, but it would be nice to be able to run call of duty @ 1024x768 smoothly ;)
Curto
43
I'm going off the prices on pricewatch.com .... after looking closer it does look like a stock 9600.
Lets start from scratch :)
What video card would you recommend for a $100 budget....
I'm looking at: Gainward FX PowerPack! Ultra/760 . Good price, nice card, and the one in my main pc is also gainward...
modedepe
3,474
Ok the card you linked is not an ultra. It's a 5600xt. Basically, it's a horrible price, and a POS card. If you like the ti4600 you have currently, you might think of getting another (or 4200/4400).
RussianSensation
19,458
765
If you can get this Albatron geforce4 4200 128mb 3.3ns (will oveclock to 4600 speeds easy) $90, or some equivalent of a good overclocking geforce 4 4200, you'd be way better off than getting a slow direct x 9.0 card. Consider this, Geforce 4 4200 is FASTER than ANY Geforce FX card in HL2 using direct X8.0 code in comparison to FX using direct x9.0 code. And any derivative of 5600FX is even slower than it in 8.1 mode! Unless you are getting an Nvidia card for current games and its something of at least 5900xt speed, I wouldn't even consider the current Nvidia generation hardware.
Summary:
I know this is a bit off topic for your question but...
Best cards:
Around ~$100 - Geforce 4 series
Around ~$150 - Radeon 9600Pro/XT
Around ~$190 - $210 = Radeon 9700Pro/9800Pro
Now with recent price drops of the 9700 and 9800 line to $190-210 level, getting 5900xt isn't even a good alternative.
Curto
43
How are ATI's as far as drivers go? I had a 9700 pro when they first came out and had stability problems, even when I changed from a a7v8x to a7n8x.
Right now the pc I'll be putting the new card in is a a7v8x (via kt400 chipset)... how is compatibility between them and ati cards now?
I might stretch to $150 ;)
Jun 14, 2003
10,442
the 5600xt and the 9600 256....waste of money.....go for a 9600pro if u can
but like you said ....comparison to 9700pro......there is no comparison 9700 will win hands down at any thing...theres no way a 4x1 core with 128bit memory can even get close too the 8x1 and 256bit mem of the 9700.....y did u ever get rid of it!!!!!!
modedepe
3,474
Well if you stretch a little, get a 9600 pro for around $130, or a 5900xt for $159. And yes, a 9700 will destroy a 9600 pro.
kylebisme
9,396
i'd guess you had something set up wrong as most people had great stablity with the 9700pro, even when it first came out.
no problems at all, just make sure you get the latest via drivers or you won't have full agp acceleration.
Curto
43
I got rid of my 9700pro because at the time I wasn't using it... I bought it to play games, then got a job working way too much ;) so I traded it for the current ti4600 I have and made a profit on it ;)
Now, still working, but having more time, I'd like a nice card for my other box... it doesn't have to be blazing fast, but I'd like the best bang for buck and acceptable performance for games @ 1024x768
Agamar
The 5900xt is showing a good lead compared to the 9600pro, a little closer with the 9600xt. I could get both the 9600xt and the 5900xt at the same price, so I chose the 5900xt for the better driver support. I was burned by ATI twice already with drivers (ATI AIW 128 Pro under Win2k and ATI XPERT 128). I think I made a good decision.
kylebisme
9,396
lol, wow talk about holding a grudge over some old as cards; i couldn't get my tnt to work with any nvidia drivers in window xp, but i hardly hold anything against nvidia for that. ;)
regardless, the 5900xt is a considerably faster in any game out now. it is slower than the 9600xt in ps2.0, although depending on how long you wind up holding onto the card that could hardly be an issue.
PCTweaker5
Banned
Jun 5, 2003
2,810
You made the best decision you could have made in that situation. Ive been burnt twice as well and will soon be having my skin scrapped off by Nvidia.
PCTweaker5
Banned
Jun 5, 2003
2,810
Ya it should be noticeably faster but dont expect a whole lot. I think you'll like it though if you dont have any problems. If you do then just get a 5700 Ultra instead which is probably what I would get if I was deciding between a 9600XT and a 5700 Ultra. Or if you can afford more get a 5900 Ultra which should be quite a bit faster than that Ti4600.
Curto
43
Enough difference to be bothered putting it in this pc and moving my ti4600 to my other secondary box?
The boxes are almost identical as you can tell from my first post...
SneakyStuff
4,294
In terms of DX8 performance, it won't be a whole lot better, but for DX9 games, it will be, I can gaurentee you that.
