Radeon 9500NP (mod-friendly) for $117
Originally posted by: Purgatory-Z
It says 128Bit memory path? I thought the L shaped 9500's had 256 bit memory interface?
They have 256 path but is is disabled. You need to flash the bios or use special drivers to enable the path.
Right, everything like the extra 4 pipelines, 256-bit data path, etc. are upgraded if you flash the bios. I personally use the Omega drivers as I've found them to be the best on my systems. I run the same clock speeds as the 9700 Pro, no extra fans/heatsinks, and my systems have been fine for over a year.
I also heard there are certain 9800SE models that can be flashed to 9800 Pro levels (been reading reviews on NewEgg) but I have no experience with them.
The 256-bit memory path is either there or it's not. It can't be enabled through anything software related. If it has L-shaped RAM, it has 256-bit memory all the time, even when it's just running as a 9500.
Now, the 4 extra pipelines can be enabled by software, but not simply a BIOS flash. You'll need to use Omega drivers to get the extra pipes without doing a hardware mod as well.
you are not guaranteed a 9700pro. I bought one last year and it wouldn't work. Had terrible artifacts with the mod enabled.
Wups your completely right. Mind blanked on that one.
EDIT: Nevermind, the OP had it in his post (was $117, now $117) 🙂.
They even state in the specs that it's L-shaped 🙂.
IMO, you're better off getting a used 9700 pro from the fs forum. It's probably a few bucks more, but you KNOW you'll get 9700 pro performance. The 9500 > 9700 mod isn't as good of a deal as it has been in the past.
