- Dec 8, 1999
- 24,206
- 14
- 76
I found this in the fs/ft section in this forum. It has been hard modded / flashed to 9700 pro. I asked party to ship first which they kindly did.
After installing this video card I found that 3dmark 2003 and Aquamark were very dark when they ran. Only the Nature scene in 3dmark appeared clear.
I also noticed after useing the video card for awhile my eyes began to hurt. I dont know what is causeing this as I didnt change any settings on my monitior
The next morning I came in to use the computer and found the monitior was in suspend state. I moved the mouse to awaken it from this state only to find it wouldnt. I had to press the Reset button when I did this I got video signal again and proceeded to go back into windows. Once in windows after a short period the monitior blinked for a second then went blank again. I had already been in power management and set it so monitior would not shut off. Once more I had to press the reset button to reboot the machine to get video card signal. This has happened so much I had to remove the radeon and reinstall my G400 Matrox in order to use the computer again
Here is what the system is
MSI K7d Master L [dual processor amd board]
Two 2400+ barton laptops at 2600+ [ these are perfectly stable with previous card]
Pcpower & Cooling 510 watt powersupply
OS is Windows 2000 pro with SP4
Directx9 is installed
Newest Catalyst Drivers installed from ATI website
I have tried disableing these items in bios , which did little if any good at all
Disable Shadow for Video
Disable Fast Rewrites
Disable AGP Anti liaseing
Disable AGP Compensate
Some of these settings I dont understand and could use some help in setting up the bios correctly or guidance in what drivers are best for this motherboard.
Any help is greatly appreciated ,
Hugs
Jen
Hugs
Jen
