I have what I think is a Radeon 9500 non-pro. The reason I say this is because the maunfacturer's label says Radeon 9500, but the label put on the card by the reseller says 9500 pro. So, on with the questions!
1. Is there a definitive way to tell which card this is? It shows up under winXP as a 9500.
2. How does this card perform as compared to a GeForce 4 Ti4200? I have a 128 MB Gainward Golden Sample card with 3.3 ns ram. Are they on the same playing field? The card will be in an Asus A7V8X deluxe mobo.
Any insight or help is greatly appreciated. Thanks!
EDIT: The core clock is at 276.75 MHz, therefore showing it is a non-pro. Any way to mod this thing into something higher? 🙂
