Heyo. I recently switched from a Geforce 2 MX to a Radeon 9500 Pro (Sapphire Atlantis, 128MB VRAM). Now my system (Win98SE) tends to lock up quite often. Sometimes it simply completely freezes (A), sometimes the monitor gets turned out and switches to energy safe mode (complete lock up inclusive) (B).
I thought it might be related to my power supply (300W), but I tried various games and 3D apps for about two hours and the system was absolutely stable while I was testing them. The problem seems to be related to desktop apps. I noticed that, for instance, ICQ (2000b) seems to trigger the lock ups. Sometimes the attempt to install a program results in aforementioned B. Apart from that it appears to freeze randomly while I'm surfing the web.
I started with Catalyst 3.6, but after noticing the problem I switched to Catalyst 3.7. The lock-ups still occure. Other system specs: Athlon 800MHz, Via KX-133 MB (4in1 v4.48), 256 MB RAM. Any suggestions on what might be the source of this? My system was stable before and the gfx card is the only component I changed. Thanks in advance.
