Hi. I'm running a Athlon 2100+ @ 2100 ghz and I have a Radeon 9500 Pro. I might get a 9700 Pro. How big of a performance difference would I get? Or would it be bottlenecked by the CPU? Thanks guys.
Your CPU is fine.I had a 9700 Pro on a 2100+ and its a really nice card.I can't say how big a difference from the 9500 Pro But I would assume a pretty good performance increase.
This might help you out a little bit, if you're familiar with 3D mark 2001 se. I had a 9500 Pro 128MB in my system and got a score of 11,200 with an Athlon XP 2100+ at stock speed. I then put the 9700 Pro in and I got a score of 13,950. So if that tells you anything..
I do use 3dmark its about 12000 now. I OCed my CPU to 2120 mhz. My LCD is only 1024 x 768. But I want to turn on 6x FSAA and 16x AF. My question is... will CPU bottleneck Vcard performance?
As far as turning everything up with a 9700 Pro and your current CPU, I would'nt worry about it. Your current system will more than handle it. But unless you intend to "max everything out", I would'nt upgrade at this time. Wait a month or two.
well lol i was going to buy it...ironically my mom who doesn't know how to use internet and email...her comp has the 9700 pro a better video card than mine i'm just going to switch it
