"Conclusion
It's clear that this is the same RADEON 9000 just under another name. Thankfully, Gigabyte has equipped its card with VIVO to differentiate it from the previous RADEON 9000. The price is at the level of the older 9000 cards.
However, the situation is not as simple as it should be for customers because the RADEON 9200 is slower than the RADEON 9100 (former RADEON 8500LE), and the higher index of the 9200 may confuse them.
Highs:
Good 3D performance for the entry-level sector, and full DirectX 8.1 support;
High build quality;
Reliable and stable operation;
Decent overclockability;
VIVO support;
Lows:
The 128MB card has the same performance as the RADEON 9000, and it makes no sense to rename the card because of the born-dead AGP 8x function;
RADEON 9000, 9100 and 9200 may be confusing consumers. "
click here for the results from a recent digit life review
Here's another review which shows the exact same thing:-
sapphire radeon 9200 review at beyond3d
Highs:
High build quality;
VIVO support;
Lows:
