Completed pics
Heatsink and vidcard prepared
close up
mounted
close up
I just bought an xp1700 and a radeon 9100 to put in my kt7a w/512mb ram for a quick and cheap bedroom computer
Quiet is paramount to this project
so far the CPU has reached 1885 and the vidcard is at 300core 275mem
those speeds may come down once i get it in a case and quieted down (use Zalman cnps6000 copper set to quiet)
The radeon 9100 has a very loud fan on it (in relation to the reset of the system)
I would like to replace this with an old passive heatsink from a p3
I will need to do some trimming of the heatsink and some bending of the fins maybe but thats okay i'm not worried about all the pci slots this will take up
so... my question is will this be adaquate cooling? (case is well ventilated although all fans are set to 5v or 7v)
close up
mounted
close up
