Argh -
pic of my computer
yes it is messy, missing drive bay covers, and a side panel, but that is besides the point.
I modded my radeon w/ a trashy cpu HSF, by drilling holes in it (the HSF) and using the stock holes on the radeon. Now, I get "artifacts" in 2d modes (from POST until it loads the right drivers, then it is fine.) but it is fine in 3d (a little slow though I think, but that may be from 256mb pc2100 dollar-store brand RAM). It does this in both linux and windows. My specs are:
2.4b ghz P4
Gigabyte 8PE667 Ultra
256mb PC2100 RAM
128mb Sapphire Radeon 9000 Pro
120gb Maxtor 7200RPM 8mb
24x12x48 CDRW
trashy case
enlight (i think) 300W PSU
And it never did this before I modded it, so I think that has something to do with it. I am confused though, since it corrects itself with the proper drivers. What is the problem?!?
BTW -
1) Which version of the catalyst drivers are best?!?
2) Is it actually worth installing directX 9 if I'm not playing any directX 9 games?
thx
pic of my computer
2.4b ghz P4
256mb PC2100 RAM
24x12x48 CDRW
trashy case
BTW -
thx
