Originally posted by: Duvie
Where will the rumored 9500 and 9500 pro fit into that???
Much faster than all those cards
Considering it is a DX 9 card, and rumored at being exactly the same as the 9700 but with a 128bit-memory pipe instead of 256bit-memory pipe, (i've heard other rumors at it having 4 texture units where as the 9700 has 8? ) at any rate, it'll outperform all the cards now, although cost more. It'll be somehwere in the GF4 performance range.
Also, the GF3 Ti200 DOES NOT outperform a Radeon 9000 in anything i've seen. With 3dmarks, on the same system specs as mine, i've seen GF3 Ti's do on average about 500 points lower than mine. (i hit around 6000, they hit around 5400, 5500 depending on how tweaked out it is). Plus, you get better DVD playback, 2D, depending on the card, the Radeon9000 has DUal Ramdac's and has DVI, S-Vid and DSub 15.
With regards to a 9000 to 8500LE, the 8500 will outperform it for sure. Also, note that we over at Rage3d has not been able to oc the 9000 (it's clock locked in the BIOS), we've been trying to work around it (first we had problems dumping the bios w/ ATIFlash 1.0 which is widely available, and had to dig up V1.1, and right now we can't seem to edit the bios w/o it messing the checksum up and not recognizing the card after flashing w/ the modded bios) so your best bet would be for the 8500LE. I wanted to get a 8500LE 128mb however i couldn't find it ANYWHERE for $150 CDN, so i picked up a Radeon 9000 128mb. Bad idea. I shoulda gotten the Radeon 9000 Pro 64mb (btw, 64mb to 128mb makes no difference in performance on the R9000 cards, can't remember the review i read that on though). So if you can find it, get a 8500 128mb LE or not, (they oc well). Btw, dun by Xelo (they really suck, downclock's everything, although the 9000's clocks are the same for ALL OEMS
since ATi seems to have imposed stricter rules, 250/200 for R9000 and 275/275 R9000 Pro) or any other third part realy. Best is Sapphire tech (since they actually manufacture the cards for ATi, so it's like buying a built by ATI card w/o the increased costs), if not, pick up a 9000 Pro. At any rate, both are great cards for the price, and wont disappoint. Hope that helped a bit.
