I still have a GeForce 2 GTS 32MB but it's crapping its pants and I kind of want some VO since I've got so used to it on my dad's laptop. So here's some cards I found:
Hercules 3DProphet 8500LE 128Mb AGP OEM £59.99 (specs say it has DVI and VO)
Crucial Radeon 8500LE 128MB DDR AGP RP DVI VO £61.08
Connect3D RADEON? 9100 128MB + VGA + DVI-D & TV £64.61
Connect3D Radeon 9000 Pro 128MB DDR AGP RP DVI VO £81.00
If I'm not mistaken I can just update the bios' of the 8500LEs to 8500 and then 9100 right? Will this cause any heat problems though? I'm going for an 8500LE but Hercules or Crucial?
On the note of tv out, is there such things as a female to female s-video adapter? I would prefer to link a 10 metre s-video cable and 1 metre s-video to composite cable with a cheap adapter rather than spend £10 on a 10 metre composite cable.
EDIT:
I'm gonna add some FX5200s to the list, getting confusing now. None of these are Ultra. I could get a Ti4400 for the price of a 5200 Ultra.
Inno3D GeForceFX 5200 128MB DDR AGP RP DVI VO £70.00
MSI GeForce4 FX5200 128MB AGP W/ TV Out + DVI (OEM) £63.35
Gainward GeForce FX 5200 128MB DDR VO £73.78
Gainward GeForce FX 5200 128MB DDR VO DVI £87.44
AOpen GeForce FX5200 128MB DDR AGP RP DVI £84.50
AOpen GeForce FX5200 128MB DDR (550Mhz 3.6ns) AGP RP DVI £84.50
Leadtek GeForce FX 5200 A340 TDH VO DVI 128Mb (4ns) £89.87
EDIT:
