RADEON 8500DV and Tyan Tiger MP?
JohnRich
NO!!
Not in my case.
I LOVE THE R200 but it doesnt seem to get along to well with the tyan mp 2460
The 3276 drivers ran like PURE crapola with the tyan and after a whole lot of tinkering to get the 3286 drivers to actually install it now only runs like HALF craploa. The 3dMark benchmarks with are off the chart and RTCW runs GREAT!!! As for other games not so the case. For example 1Inasne (a cool game if you ask me) doenst work properly, you get all the sounds and instrument cluster of the vehichles but no view of whats going on or where you are at.
Also after a good while of playing Return to Castle Wolfenstien I get little flickers randomly throughout the screen on my DVI panel almost as if it was like a bad signal on a tv.
Darkhsun
26
hmm.....my 8500DV runs fine with my S2460.
Can you tell me what speed I can effectively overclock this card to? it's a little on the slow side. I don't want to fry it though. :)
Jfrag Teh Foul
3,146
I tried to install a Radeon 8500 in a Tiger MPX and it flat out wouldn't boot. I then called up tech support and they told me that right now it would not work, but in the near future they will be releasing a bios update that should fix it.
Pabster
16,986
There is a beta BIOS revision available to allow the 8500 series to work properly with S2460.
