Radeon 8500 shaky/flickering display
Sean453
53
I just installed a Radeon 8500 64 MB to replace my 32 MB Geforce DDR card on my XP machine. I purchased the card from Ebay and it was just the card itself. I downloaded the latest windows xp drivers from ATI's website. In Windows it works fine, but in any fullscreen 3D game the display seems to be shaking a little bit and flickers and sometimes random lines flash in the screen. Anyone else have this problem and know how to fix it? Thanks.
Sean453
53
The lines are vertical. It gets worse as my FPS increases. But the screen shaking is constant.
Unforgiven
1,827
sounds like you got a video card thats on its last legs. i had the same thing happen with my g4 ti4200 on 3 different cards and it was the video card each time... sounds like you got jobbed on ebay dude :(
Sean453
53
hmm are you sure? It runs absolutely great except for these small bugs. Maybe the Nvidia drivers aren't gone? They should be but maybe not. I've heard a couple people mention a program called Driver Cleaner so maybe I'll try that and reinstall the ATI drivers. If that doesn't work then maybe I'll give the Omega drivers a shot.
