HELP!
I have a Radeon 6900 of some sort, and I upgraded one of my monitors to an Asus PB278Q which is 2560*1440. I used dual link DVI to connect it, but couldn't get it above 1920*1080. From reading online ATI cards don't support that resolution via dual link DVI. So I tried HDMI. But again, I can't seem to change the resolution above 1920*1080. I also tried display port, but the computer doesn't even recognize the monitor is plugged in.
I also can't display on both my old display (via DVI) and the new one at the same time. When I try to extend or duplicate the display on both it says unable to save these display settings. I am able to switch from using one display to the other.
I tried HDMI and displayport with the old monitor disconnected - but basically get the same result: display port doesn't work at all, and HDMI wont go above 1920*1080. Any ideas?
Weird, I searched google about a dozen times and don't seem to find anyone with these kinds of issues.
This is the output from Catalyst Control Center:
Driver Packaging Version 14.301.1001-140915a-176154C
Catalyst Version 14.9
Provider Advanced Micro Devices, Inc.
2D Driver Version 8.01.01.1423
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 9.14.10.01061
OpenGL Version 6.14.10.13084
Mantle Driver Version 9.1.10.0034
Mantle API Version Not Available
AMD Catalyst Control Center Version 2014.0915.1813.30937
Graphics Card Manufacturer Powered by AMD
Graphics Chipset AMD Radeon HD 6900 Series
Device ID 6719
Vendor ID 1002
Subsystem ID E182
Subsystem Vendor ID 174B
Revision ID 00
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 013.012.000.020
BIOS Part Number 113-4E182PROXX-T44
BIOS Date 2011/08/16
Memory Size 2048 MB
Memory Type GDDR5
Core Clock in MHz 880 MHz
Memory Clock in MHz 1300 MHz
Total Memory Bandwidth in GByte/s 166.4 GByte/s
Via device manager I disabled the Intel HD 4000 graphics, but it still shows up via the system info tool. I'm only plugging monitors into the radeon card. Here is what system info application lists under display:
Name AMD Radeon HD 6900 Series
PNP Device ID PCI\VEN_1002&DEV_6719&SUBSYS_E182174B&REV_00\4&15001D53&0&0008
Adapter Type AMD Radeon Graphics Processor (0x6719), Advanced Micro Devices, Inc. compatible
Adapter Description AMD Radeon HD 6900 Series
Adapter RAM (2,147,483,648) bytes
Installed Drivers aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver Version 14.301.1001.0
INF File oem16.inf (ati2mtag_NICayman section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1600 x 1200 x 60 hertz
Bits/Pixel 32
Memory Address 0xE0000000-0xEFFFFFFF
Memory Address 0xF7D20000-0xF7D3FFFF
I/O Port 0x0000E000-0x0000E0FF
IRQ Channel IRQ 4294967294
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\atikmpag.sys (8.14.1.6398, 562.50 KB (576,000 bytes), 9/15/2014 5:59 PM)
Name Intel(R) HD Graphics 4000
PNP Device ID PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09\3&11583659&0&10
Adapter Type Intel(R) HD Graphics Family, Intel Corporation compatible
Adapter Description Intel(R) HD Graphics 4000
Adapter RAM (2,080,374,784) bytes
Installed Drivers igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver Version 10.18.10.3958
INF File oem13.inf (iIVBD_w7 section)
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Driver c:\windows\system32\drivers\igdkmd64.sys (10.18.10.3958, 3.65 MB (3,828,152 bytes), 10/1/2014 7:54 PM)
Device ID 6719
Vendor ID 1002
Subsystem ID E182
Revision ID 00
Memory Size 2048 MB
Memory Type GDDR5
Bits/Pixel 32
