Discussion Radeon 6500XT and 6400
Page 25 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
GodisanAtheist
7,148
7,645
Just getting a thread up for this. Navi 24 will ride... Q1 2022... ish.
I fugure the 6500XT lands ~5500XT territory for ~$200.
Reactions: Tlh97
LightningZ71
1,792
2,151
Look at the amount of die area taken up by the 16GB L3 cache in the CCX. To be useful, that's about the amount of space that adding an IfC would take on Rembrandt. That's a significant amount of space and would seriously dent their die per wafer throughput in a market that's literally devouring ANYTHING that's thrown at it. For Rembrandt, there was just no competitive need. What they have is significantly better than Xe in Tiger Lake and likely also in Alder Lake. Raptor Lake isn't looking to make a significant change there either. It's going to be 2023 before Intel has anything that's going to be threatening AMD in that regard. AMD's biggest performance deficit is in their CPU performance, and that's certainly where their next APU is expected to make the biggest changes. While there will likely be some tweaking of the iGPU for it's move to N5, It should still be largely similar.
We might see something significant for 2024 on an improved/tweaked N5 process based around RDNA3 and an IfC.
Reactions: scineram
Shivansps
3,875
1,530
-Its weird cause I thought that was sort of the whole point of RDNA2... Running fast under restricted bandwidth situations.
My first thought was "this thing is going to take IGPs by storm".
Yet... No IC for IGPs with RDNA2 (wow that was a mouthful)? I understand having a tight transistor and power budget there, but letting IGP and Cores share a nice fat IC L3 pool seems like a no brainer.
Maybe the worry was the IGP would cannibalize their low end or add in card sales?
It looks to me they havent figured that one out yet, it may come with RDNA3/Zen4 APUs.
But, RMB IGP still have a larger than usual L2. It has to be doing something.
GodisanAtheist
7,148
7,645
-Zen 4 is rumored (confirmed?) to have every processor ship with an IGP on the IO die.
By getting away from monolithic APUs where any additional die space has a disproportionate impact on yields due to an already relatively large die size, we may see AMD include a splash of IC on the IO die since its already reasonably compact to begin with.
Then again, Zen4 will be DDR5 only which should naturally push up bandwidth available to the IGP, so AMD might just lean on that exclusively for a performance bump.
Maybe Zen5? Anyhow, this is way off topic at this point.
waffleironhead
6,938
455
Looks like we're back to AMD's derped out naming schemes. The 680M (WHY AMD WHY CAN'T YOU JUST STICK WITH A GOD DAMN NAMING CONVENTION?!) is now faster than the 6500XT, in at least a couple scenarios.
Que OEMs pairing the 6900HX with a 6500XT and the weaker discrete card bringing the overall laptop performance down...
Oh AMD, you were executing too flawlessly for too long. Got too close to the sun I guess.
Would you prefer they keep their old naming scheme, where various IGP were all called vega8 regardless of their clockspeed? I mean the Vega8 in the 5700g is leaps ahead of the vega8 in the 2200g.
LightningZ71
1,792
2,151
Are you sure that Rembrandt's iGPU L2 cache is larger than the 6500xt? Looking at the TPU database, they have them both listed as the same. Granted, due to the 680m having fewer CUs, it has more L2 per CU, so, that may be your point.
AtenRa
14,003
3,361
It's shameful for 6500XT as a dGPU to even be compared to an iGPU. And now AMD will release the even more embarrassing 6500 soon. As Anand used to say, there is no bad product, only bad prices. 6500XT is VERY badly priced. I hope AMD kills it soon and doesn't produce more of this crap.
Why it is shameful to compare those two ??
680M = 12 Compute Units or 768 Cores
6500XT = 16 Compute Units or 1024 cores
Reactions: Mopetar
13,588
6500 XT was billed by AMD as the "For Gamers, NOT for miners" card. They succeeded in the latter but not in the former. They insulted gamers. I'm waiting to see if Nvidia pays more respect to gamers with their 3050 4GB card.
Reactions: Ranulf
GodisanAtheist
7,148
7,645
-I'd prefer they kept it in line with the rest of their GPU arch.
12CU RDNA2 should be 6400i or 6300i or something like that.
Shivansps
3,875
1,530
Yes, AMD said 2MB L2, RX6500XT has 1MB, the Van Goth on Steam Deck also has 1MB. Its not a lot, but ill take that over nothing.
AMD-Radeon-600M-680M-660M-RDNA-2-iGPU-Performance-Benchmarks-on-Ryzen-6000-APUs-_12-1480x828.png
TESKATLIPOKA
2,508
3,009
15W TDP vs. 107W. It should be a no contest. Yet the 680M comes out on top in RT. Someone at AMD needs to be demoted, if not fired.
Incorrect.
It was 6900HX and that is a 45W APU. Even the IGP part should consume more than 15W.
BTW, It was already explained why 6500XT loses to Rembrandt in it.
Choose a game without RT or high memory needs, then It will be naturally faster.
Reactions: Tlh97 and scineram
13,588
Says 15W.
RT or not, a dGPU named 6500 "XT" should not be losing to an iGPU.
The model name is incorrect. Should be 6200 non-XT and the upcoming 6500 should be 6100 non-XT.
There's a marketing idiot in AMD's GPU division. His balls need some nice electroshock therapy so he doesn't pull something like this again.
TESKATLIPOKA
2,508
3,009
Says 15W.
And that should prove what? 15W R7 6800U also uses 680M as an IGP(official link), and It certainly won't use the whole shared TDP for just the IGP.
There is no official info how much It actually consumes from the shared TDP as far as I know, but with a shared TDP of at least 45W I would expect a lot more W going to the IGP I wouldn't even be surprised If It was 15W(CPU) and 30W(IGP) for example.
It was already mentioned why 6500XT performs worse(4GB + 4xPCIe), and that only in an RT title. Show me a non-RT test where this IGP beats RX 6500XT?
There is no such test!
Both 6400 and 6500XT are weaker than RX 6600 (XT), so there is no big problem with the name, the IGP has a totally different name.
Reactions: Tlh97
Shivansps
3,875
1,530
Maybe no now but as things are, there may be eventually, specially vs the desktop version of RMB. The problem the 6500XT has is that there are cases where the effective bandwidth is a lot lower than 144GB/s + wharever the 16MB IC gives, due to texture streaming. And texture streaming is here to stay.
LightningZ71
1,792
2,151
While I'm sure that there are some other factors to the speed difference, if the iGPU indeed has twice the L2 as compared to the rx5500 xt, then, it has twice the capacity for ray stream buffers and tree buffers in cache as opposed to going to main memory. Having a sufficient amount of those buffers is important for ray tracing performance. Granted, I'm not sure why they would over-provision the iGPU over the dGPU in this case, as it doesn't make a lot of sense from the outside, however, the larger L2 doesn't just serve the RT units, instead, it works to reduce the demands on the main memory to a certain degree, which is extra important in an iGPU. It may have been cheaper for AMD to stuff a doubled L2 in Rembrandt's iGPU than to include an infinity cache and scale well enough to make it worth the impact to the overall chip size.
Personally, I'm not 100% convinced that there IS a difference between the L2 cache in the iGPU and the 6500XT yet as I keep seeing conflicting specs for both units. It would seem to neatly explain the performance differences, but, its also likely that something else is going on.
Panino Manino
869
1,117
At this market class why does anyone care about RT?
RT is an unplayable experience on all of these. nvidia, amd, iGPU, etc. RT is pointless on the low end, completely pointless!
Making arguments based off of unplayable experiences is pointless stupidity!
But it looks nice when you have youtubers showing Cyperpunk with RT running at playable framerates.
Also, it was a promise that AMD made.
