- Nov 9, 2009
- 8
- 0
- 61
I just noticed last night that my Radeon 5870 is running hot at idle.
I opened speedfan 4.49 and my gpu temp is 83-89c at idle. There is nothing else running on my computer at the moment. I can hear the fan churning at 49%.
As a result my system temp is 56c when at idle it is usually below 40c. CPU usage is below 1% and there is nothing else running. I don't get this.
I tried reinstalling drivers and that seemed to calm it down last night and I was able to use the computer as normal, but now today after using the system - which has not been changed in any way that I know of in at least 6 months, the temps are back up.
What steps can i take to a) fix this b) check to see if my card is failing c) check to see how and why the drivers seemed to help last night.
The Catalyst control center keeps shutting down when I try and get some information so it essentially is useless at this point.
Again i have played no games nor have I stressed the machine in any way other than surfing the web in the last 48 hours.
Thanks in advance.
Thanks in advance.
