ThorofThunder
I've researched graphics cards and their respective prices and have finally settled on a Radeon HD 5850. I have no idea what brand I should lean towards, though ASUS, Sapphire, and XFX are the commonly chosen ones.
I plan to overclock it and will need to alter its voltage. Reading a bit up on this, I've come to an impasse and can't seem to find an answer.
If I want to OC the 5850 to just-under-stock-5870 levels, then I'm going to need to change the voltage of the 5850. However, apparently I can only do that, to the most effective degree, with a "reference card." What is a reference card, exactly? Would a Sapphire Vapor-X 5850, as a theoretical example, be considered a "reference card"?
I apologize in advance if this question is ridiculously stupid.
