Radeon 5850 fan is louder than normal. Warranty has already expired, what do I do?
Paktu
508
I tried cleaning out my case and spraying with some compressed air to no effect. It seems like after a while, the noise gets less noticeable as the computer heats up. Would WD-40 do anything, or is that a stupid question?
Despoiler
1,968
773
WD40 is NOT primarily a lubricant. It's a solvent that removes rust and then a crap lubricant.
Feb 19, 2009
10,457
10
Take apart the 5850, clean out your fan and heatsink which is most likely blocked with dust and maybe even hairballs. :0
I recently cleaned mine, put in a new ocz freeze thermal paste and it runs a good 10C cooler.
Zanovar
3,446
232
I had this prob with my 5850,the fan would grind and rattle but only at 30% fan speed,very strange.so i just bypassed that speed with afterburner and has been grind and rattle free ever since.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
When I booted up my 5850 for the first time yesterday it was making a knocking noise when the fan was on low. All the sudden it just went away... I don't have confidence that it will remain quiet.
wand3r3r
3,180
The bearing on the fan is almost certainly going out. Had the exact same issue with a HD 5870. First the knocking sound kind of quietly, then it disappeared. Then a month or two later it came back and a week later and finally it was knocking/rattling like crazy. It took a while but if the sound is like a ticking knock it's almost certainly the same thing. Time to replace the fan (or the complete cooler with a better aftermarket alternative).
