Originally posted by: Lithan
That's how it's SUPPOSED to work, but that fails more often than it succeeds.
8800gt WAY better than g90 gts
And which is most important?
7900gtx Demolishes the 8400 cards, does that mean that model conventions are more important than series?
The way VGA cards are named these days it seems pretty clear that the manus WANT to make it as complex as possible so they can sell crappy cheap to produce cards to people who think they are high end. Hell, the convention "XT"? That's switched from good to bad and back again three to four times in the past couple generations. Look back a little further and the same thing happened with "pro"
8800gs isn't high end any more than 9800xt was high end (I think it was the 9800xt... it was a 64bit mem 9800pro that performed HORRIBLY). It's just the top number scheme. It's at the bottom of that scheme. Which makes it third tier, or fourth/fifth depending on what you think about the new gts.
No dual gpu solution in this series>8800ultra/8800gtx/gts > 8800gt > 8800gs
which matches up with
9800gx2>9800gtx>9800gts(not released yet)>9600gt>9500gt(not released yet)
Basically the naming schemes so damn convoluted now that you can only rely on benchmarks and/or price to tell you what cards are high end, midrange and low end. 8800gs falls towards the bottom of midrange.
The general flow of benchmarks suggests for nvidia
9800x2>8800ultra>8800gtx/8800gts>8800gt>(high end ends here imho)9600gt>8800gs/8800gts(g90)(midrange ends here)>8600gts>8600gt>7600gt (9800gtx results arent here yet)
Basically all you need to know about ati right now is that it loses everything. But really, you expected a $25 card to be an upgrade for a $300 card... even if it was 3 years old. That seems naive.
Here they are: http://www.newegg.com/Product/...HD+2600Pro&name=64-bitOriginally posted by: bigsnyder
The 2600Pro should be a 128bit card. The 2400s are usually 64bit. I find it amazing you found a 2600pro at best buy for $25 of all places. Great find!
Originally posted by: JEDI
i got the 2600 pro for $25 at best buy.
i thought the higher the model #, the better the performance? (unless it's a SE model with 64bits)
Originally posted by: Azn
What are you talking about 9800pro having 64bit bus? R300 had 256bit memory bus and 8 fragmented pipes.
8800gs is a good midrange card. 75% of the full G92GTS.
Kind of like 8800>9600gt :laugh:
Why yes, yes I do.Do you mean G80 GTS ? 🙂
I was actually talking about a hatcheted version of the 9800pro, maybe it was the 9800se, one of those damn remakes of the 9800pro was god-awful. And TONS of people bought it thinking it was an improvement, and the RMA's poured in. Newegg spent months burning through all the open boxes they had of those suckers.
The 9800SE had 128mb of vram on a 128bit bus.
That's probably it then. I just remember they released it right around the time the 9500 Nonpro was released... everyone bought it but a couple guys got the 9500, figured out it could be modded to a fullfledge 9700pro (with slightly slower mem chips). And the lulz ensued. I think the 9800se was like $220 at the time, the 9500 was <$160 and the 9700 pro still sold ~ $275.
