rack case for disk farm
acaeti
103
So it comes to this - 2 computer both with >1TB of RAID 1 just isn't enough space and is too much of a pain in the ass to keep turning on and off to make available DVD images.
I am looking for a rack or pedestal case that I can jam 12+ 3.5" disks into. I have a K8N-E Deluxe motherboard with 8 ports of SATA and will be getting additional SATA controllers to connect all the disks, and plan on running 2-3 raid sets of linux software RAID-5. I guess I'll also need a strong PSU for the unit as well.
Any suggestions out there? Or tell me this is the wrong way to do it and suggest something better!
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Grab a large case and three of these Supermicro 5-in-3's. Wonderful things. :) Then all you have to worry about is the RAID controller for access to 15 SATA drives.
how much are you looking at spending?
acaeti
103
HAve you seen a case large enough for three of those? The largest I have seen is the CM Stacker with 7 external 5.25" bays, enough for only two 5-in-3 modules.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
I have one, but I'm not quite sure how much you want to spend... I can fit two more in mine I think.
acaeti
103
How about anyone seen a 4U case that has 5.25" or a bunch of 3.25" bays rotated vertical like those Apple fiber channel RAID things?
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
I could see myself spending up to $600 if I had to, but i'd rather not ;)
Okay. Enermax FS2300-BB case. 23 drive bays. Basically like a double wide. Here is a direct link. And it can be bought direclty from the manufacturer, for ~$450, plus shipping. The case itself is 100 pounds.
EDIT: Here's my pics
acaeti
103
Wow what a beast! Daddy likey :). I will have to seriously consider that, though I'm sure shipping is a mint... Thanks for the pointer though!
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
No problem. I literally did research for 1.5 years before finding this, and then tried another year to get it (I finally found out about ordering directly from Maxpoint/Enermax).
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Originally posted by: InlineFour
What motherboard are using in your server Fullmetal Chocobo?
Supermicro X5DAE. No OCing, but damn it's a wonderful board.
InlineFour
Banned
Nov 1, 2005
3,194
What are your thoughts and oppinions on Tyan boards? I just bought the Tomcat i845GL for my budget server build. Here's the thread for complete specs.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Tyan's are excellent. By far some of the more superior consumer level boards, especially for a server rig. Definitely a good choice. I had a Tyan back when I had a P4 setup, and my experience with them has been great.
Zepper
18,998
One of these: CG S101
Three of these: 4-in-3 More pix available on newegg.
If you decide to go that route or similar, I have one of the 4-in-3 cages for sale - click the link in my sig. Good luck.
.bh.
