"Race to the top" recruitment thread: Correlizer Project
bryanW1995
11,144
32
We need MOAR CORES. The Germans are bringing in the heavy artillery right now... Sorry, SETI@Germany is anyway. I think that they've brought up the strategic reserves, so a few more rigs could push us over the hump.
wayliff
11,718
9
I have added another quad core machine that will work for two days and then I have to take it offline. That will help a little.
mrjoltcola
534
Well I'll turn up the volume. I just brought up a dual socket Xeon, bringing up another one shortly. This evening I'll add at least 8 more cores.
bryanW1995
11,144
32
I wish my mega-cruncher/dora game-player wasn't down... It was pumping out 20k ppd in seti for the past year+, but the ip35 pro finally kicked the bucket. And I'm too cheap to buy a new rig until I see some BF deals...
wayliff
11,718
9
What should I do after finishing the project?
Are you asking what should you do when the race is over?
If that is so then you can continue to crunch Correlizer, if you like to aid in that project, or you can check the DC forums and see if there's another race going or you can look up another project and simply crunch for the benefit.
finally - you can opt to no longer help on any crunching (strongly discouraged - :biggrin:)
busydude
8,793
btw - did you just add your machine? I saw only a single task in your list.
I added the URL in your OP.. and it downloaded a task. It took about 14 minutes to finish the task.. and I did not know what to do after that. :p
I feel stupid.. just for asking, but I want to help. :oops:
wayliff
11,718
9
Bring up the Boinc client, select the projects tab, click on Correlizer and then click on the update button. You may have to do this a couple of times to actually see some movement...but space it by a couple of minutes.
I hope more WU will start to come down to your machine.
Thanks for wanting to help.
wayliff
11,718
9
Also go into your Correlizer Preferences, in your account, and make sure only "Correlizer Applications" is checked from the applications list and finally check the box that says "If no work for selected applications is available, accept work from other applications?".
Make sure to click on update after you're done.
SlowSpyder
17,305
1,001
My AMD 1100T, overclocked to 3.977GHz completes a work unit in 11.5 minutes.
Currently, the fastest rigs of TeAm members Biodoc (2 rigs,) mk, Rudy Toody, and ZipSpeed are ranked 2 - 6 for recent average credit (RAC.)
Join us on the list!
Just joined. Six cores @ 4GHz/2.6Ghz joining the fray... task manager is pegged, 100%. :)
SlowSpyder
17,305
1,001
Kind of wish I didn't look... :p
~430 watts with all six cores pegged for this project. I'm not at all worried about the cost, the nerd side of me just wishes for more efficiency. :)
Plimogz
678
what are your CPU, CPU-NB voltages?
And while you're at it, would you consider doing a quick test at stock speeds/volts? Though if you're too engrossed by correlizer to reboot a couple of times, I totally understand :p
On second thought nvm, the AT review places a 1100T system's load power consumption @ 160W. Good enough for me.
Edit again: though their OC'd to 3.96GHz load power results place the system at 195W...
430W you say?
SlowSpyder
17,305
1,001
I have an old motherboard, MSI K9A2 Platinum with a 790FX chip, AM2+ with four 2GB sticks of DDR2 @ 866MHz and 2.1v. My CPU is set to 1.47v, and I forget the NB voltage. :) So I am overvolted and overclocked, and I have older components that are likely less efficient. But, man, that's a big difference. I have a 1TB drive and a 640GB drive, one optical drive, six 120mm fans all slowly spinning (I like the quiet!). So, I don't know why there is such a discrepancy, unless this set up is really this inefficient.
Dec 30, 2004
12,553
Yeah, it's a bus OC on a $50 Microcenter special CPU, and the board is a $50 3 year old ASRock A780FullHD. To be honest, I'm a little surprised the board let me take the bus to 250. At least it will keep my power usage in check, the CPU seems to be voltage locked at 1.35V, which is a good thing, because I pay almost $0.30 per KW/H. (DAMN YOU CON ED!!!!)
try PhenomMSRTweaker
xylem
621
My computer has been churning through units for quite some time today.. all 8 threads have progressed from 0% to 100% many times. My account shows 0 credit with 0 pending credit. Is something amiss, or does it take the server a while to "catch up" and reflect work already done? My user ID is 1071.. same handle as I use here on AT.
wayliff
11,718
9
No...someone else has to run the same WUs that you completed for validation. Once that is done credit will come.
Sometimes it does take some time to get credit.
Keep crunching!
Rhoxed
1,051
I'm in fellas, will have all 3 rigs working it by tomorrow, main rig is already crunching.
busydude
8,793
Thanks. Just came home and started crunching!!
Markfw
May 16, 2002
26,050
15,191
OK, I joined with a 1090t AMD hex @ 4 ghz, but it says "no work available to process" in the boinc window.
Edit: now its working, but only using 34% of the cpu ??? 2 cores of 6 ?
maniac5999
503
11
You Sir are my hero. The board I'm using doesn't handle CNQ, but this CPU will gladly run at 1ghz and 0.8v, which should get me MUCH better idle power consumption than 3.4ghz and 1.325v.
However, unless I can figure out how to get MSRTweaker and BOINC to play nice, and crunch units at this ridiculously low power state, you might have taken me out of the competition here. Unfortunately like Manhattan rents, Manhattan power prices are brutal.
pandemonium
1,777
I've been meaning to get into some folding (would be my first) since I think it'd be fun to help out and put my cheap kWh to use. I'm not sure how much a Q9400 @3.2GHz would help, but why not - right? :)
