R9 290 Custom Cooler
lopri
13,329
709
What's out there? I like the card but I can't stand the reference fan's noise. I thought I could get used to it but it's getting worse, it seems. I am looking for a quick and easy fix. If possible,
1) I do not want to go through selling it and replacing it with a new one
2) Water cooling is not an option
3) I would like to avoid cutting and milling, etc. Screws are fine. I can deal with them.
Last time I installed an aftermarket cooler for a graphics card I used a Zalman VF900 or something which required two screws. Obviously R9 290 needs a much beefier cooler, but I would like to keep it simple as possible. (again, preferably screws only)
fleshconsumed
6,486
2,363
http://www.overclock.net/t/1203636/official-amd-ati-gpu-mod-club-aka-the-red-mod/0_100
You don't even have to buy a bracket, just four sets of 2x20mm screws and nuts from homedepot/menards. Drill four 2.5mm holes in the AIO mounting bracket, strap a 92mm fan using elastic string to the right side of the card and you're good to go. Optional upgrades include proper bracket if you're not OK with DIY solution, and better fans for the radiator. My 290 runs at 65-70 degrees tops with two Scythe GT AP14 in push pull config full speed (still pretty quiet for full load). I would not recommend zip ties though if you go DIY route. Proper bracket or bolt through DIY.
lopri
13,329
709
@lehtv: That looks like what doctor ordered. Thank you.
@fleshconsumed: I remember seeing those somewhere. Very intriguing solution. I will read up on it. Thank you.
Theguynextdoor
1,118
The only problem with that solution is there is nothing cooling the rest of the card. At least put on some HS's for the memory and voltage controller.
fleshconsumed
6,486
2,363
Yeah there is - there is 92mm fan tied to the end of the card, plenty to cool the VRMs. :)
