R7 240 2 GB DDR3 vs. R7 240 1GB DDR5
ankitsi5
23
i dont know the wattage of my pc.its not written on it.can you tell me if r7 250 can be compatible with my pc.
"i-ball JSW 252" is written on my PSU.NOTE: i ran my 8400 GS 1 GB GRAPHICS card on this
here's a pic of my PSU
ankitsi5
23
i decided to grab a r7 250 1 GB DDR5.
but i'm not sure about my PSU,its IBALL JSW-252
The vendor says that its 400w but i dont really believe him.
CAn you tell me if its compatible with r7 250 1 GB DDR5.
NOTE: i ran a ZOTAC 8400 GS on the same.
here's a pic :
XriHrumnM6
https://dyp.im/XriHrumnM6
MeldarthX
1,026
ok looks to be 450 watts; someone was saying 450 volts......that's more than enough for the R7 250....the 250X need external power plug; the 250 doesn't......honestly I'd go with the 250
ankitsi5
23
WHATS AN External plug?
and whats the difference between 250 and 250X?
BTW i contacted the vendor ,he said its written that thePSU supplies 450 watts,but actually it doesnt,it supplies around 300-350.Also its 3 years old.
So what to do?
IS it really neccesary to buy a new PSU.
i really cant extend my budget
Blue_Max
4,223
153
It's fine. Seriously, don't worry about it. And good choice on the video card, you'll enjoy it.
lyssword
5,630
25
yeah you only need to worry about power supply if you are getting into gtx 770/780 or 280x/290 range :p (or running 4.5ghz OC'd quad core in addition)
Piroko
905
79
That's an old "350W" PSU that I would treat as a 250W PSU (because 12V * 18A = 216W, which will be the limiting factor in a modern PC).
Still, should be enough for those graphics cards, albeit barely.
Aug 11, 2008
10,451
642
Yea, psu should be enough for the 250, but barely. The 12 volt output as piroko said is only 216 watts, which is very low for a psu rated at 450 watts. I had a cheap OEM box with a psu rated at 300 watts whichput out 240 watts on the 12 volt rail.
ankitsi5
23
OK but if a get anew PSU,then I have to make all that messy connections.
I don't know how o do that
DownTheSky
785
154
You don't need a new PSU. R5 250 is a 65W part. Probably lower. If you don't OC your CPU you should be allright.
lyssword
5,630
25
like everybody is saying, you dont need new power supply. Look at power consumption numbers. Those are in watts, that's the max total ur system will consume with that video card. Nowhere near 200w even.
ankitsi5
23
So will the R7 250 run smoothly without struggling for power with that cheap iball PSU that I currently have.(I really don't know how much power does it supply?)
So should I buy a corsair 550watt PSU or stick to the iball psu?
Blue_Max
4,223
153
Stick to your power supply.
If you have the MONEY to buy a power supply too, you can consider spending more on your video card.
The Geforce GTX 750 and 750TI are two cards that are faster than the R7-250 but will also still work well with your existing power supply! :D
lyssword
5,630
25
First you wanted to buy 450w corsair, we said ur crappy "iball" can handle your system just fine. Now 550w? where are you getting these ideas? :p
ankitsi5
23
I consulted the vendor, hr said you have to buy a new PSU.he recommended corsair 550w
Piroko
905
79
There is a chance that something can go wrong with your PSU, most likely your system will be instable or the PSU itself will simply die.
However, as you might have noticed, most of us think that this risk is very low and your PSU will be fine for now. If money is not an issue then go ahead and also buy a new PSU, -
I'd say a branded one (like Corsair) with ~450W will be plenty fine. Installation is simple, four screws to the back of the case, two connectors on the mainboard (very apparent which ones), every drive (HDD, SSD, DVD-Rom) gets one connector and case fans that are not connected to the mainboard will get one. Larger graphics cards also get one or two (your options do not). All connectors only fit their counterparts, no chance of destroying something here. If in doubt, take notes/pictures of your current connections. -
If money is an issue, try it out as is and just keep the PSU in mind for your next upgrade.
ankitsi5
23
Yeah that's a good idea.
Thnx mate.
BTW which is better Asus R7 250 1 GB DDR5 or Sapphire R7 250 1GB DDR5
