Hey all. i've got the following rig
QX6800
Asus Striker Extreme 1303 bios
Corsair TWIN2X2048-9136C5D x2 4gb total
Enermax Galaxy 1000w
2x XFX 8800 Ultra Ex 675 core/ 1667 shader/ 1160 mem
Creative x-fi elite pro
WD 500gb sata 2 HD
cooling
Thermal Take Armour case Customized
5x 120mm fans
3x 80mm fans
Thermal right HR-07 ram coolers
Ram also has additional small zalman heatsinks stuck on them.
All 3 large parts of the asus heatpiping around the cpu for the chipset has fans on.
Zalman Resorator XT cooling video cards and cpu.
i have been madly trying to overclock this rig and the most i can get out of it without crashing is 3.66ghz which seems low.
i can't seem to get the fsb bus above 333 if i do the system just will not post.
If i drop the ram timings to 4-4-4-12 1t and increase the voltage to 2.4 it won't post.
the settings i use for voltages are.
vcore - 1.5125
1.2v ht - 1.25
nb core - 1.45
sb core - 1.60
cpu vtt - 1.55
fsb = 333
multiplier = 11
disabled
sli broadcast aperture
nvidia gpu ex
cpu internal thermal control
limit cpuid maxval
enhanced c1
execute disable bit
virtulization technology
enhanced intel speedstep
when setting the system clocks i choose unlinked and manually set the ram speed to 1142, timings are set to stock 5-5-5-15 2t.
i've seen rigs pushing the 4ghz barrier which is what i would like to aim at. i would also like to tighten up my memory timings.
i have worked with computers for years am an avid user of linux and do alot of programming and scripting.
only recently have i decided to seriously get into the overclocking scene so i am fairly new to it, but i do understand most of the concepts and theory.
i've read alot of guides but if anyone can recommend any comprehensive ones it would be most greatly appreciated.
guides i've read are
nvidias own 680i overclocing guide.
the guide on here written by graysky which i found excellent.
also a good guide on overclock.net as well which pertained mainly to the P5N32-E board.
Any advice on how to get a bit more juice outta my rig would be amazing.
thanks in advance
alex
QX6800
WD 500gb sata 2 HD
cooling
5x 120mm fans
3x 80mm fans
vcore - 1.5125
1.2v ht - 1.25
nb core - 1.45
sb core - 1.60
cpu vtt - 1.55
fsb = 333
multiplier = 11
disabled
nvidia gpu ex
limit cpuid maxval
enhanced c1
execute disable bit
thanks in advance
alex
