- Mar 11, 2000
- 23,996
- 1,619
- 126
OK, I've got a central AC unit and it seems to be working. I get very cool air upstairs out of the vent, but unfortunately the volume is low. It seems the air flow wasn't designed right for cooling in this house. Adjusting the duct dampers helps a bit, but not much. I've also closed most of the 1st floor vents and sealed all of the basement vents. That also helped, but it's still not enough.
In essence, if it's 30C outside, the AC can bring the 2nd floor down a few degrees, but not more than that. Part of the problem is the fact that I've got great big windows, and cathedral ceilings as well. No attic.
We considered putting ductless units up here to compensate, but they are $$$$. So, I'm thinking of getting a window unit for the bedroom for the time being. However, most of the ones I've come across aren't very quiet.
What are the quietest window units available? I figure I'd need about 8000-10000 BTU. The room is 275 sq. feet.
