quietest power supply?
Conroy9
611
it seems that the top choices for quiet power supplies are the enermax whisper supplies and ones from quietpc.com
I read some posts here that the enermax wasn't really that quiet..?
has anybody tried both? which is better? is there a better other alternative ?
i don't want to open up my power supply to replace the fan
Noriaki
13,640
I've been asking after Enermax Whispers lately, and everyone seems to think they are quite quiet.
The EG351P-VE and EG451P-VE (330 and 430 watt) everyone tells me they are very quiet.
I don't have one, but I'm searching after a fairly quiet PSU myself.
Sharkmeat
467
Check out "pcpowercooling.com" they have the best silencer Power Supply,s but they are pricey,but the best cost a little more.
cwand
Banned
Jun 26, 2000
707
I have the Enermax EG451P-VE and the word "whisper" should not be associated with this thing. It is definitely not what I would consider quiet.
I also have a 400W Sparkle that's about the same in terms of noise.
If you want "quiet" look elsewhere.
LickEmSmack
389
I like the Antec temperature controlled power supply. If your case isn't running hot to begin with (like a regular clocked PIII) then, it really doesn't spin the fan very fast and generates very little noise. I have one and it is probably the quietest part of my sys. Even the Taisol HSF is louder and that's supposed to be the quietest HSF on the block.
Dug
3,469
What I do know is that PCPower and Cooling has an extremely quiet power supply. I know because I have one. It's so quiet that I can hear my chipset fan and my Geforce fan over it.
I was thinking about getting an Enermax, because I thought I need more power, but I've heard that they're really not that quiet. I wish I could try before buying.
The only reason I was thinking about upgrading is because I'm running a T-Bird at 1.4Ghz, a Geforce2 GTS Pro, 2 IBM's, CDROM, CD Burner, 3 case fans. And the power supply is only 275 watts.
I did call PCPower and Cooling about the 275watt version and they said their power supplies are built with such high standards that I shouldn't have any trouble at all running my setup. When I asked about upgrading to the 400watt version they said it was unecessary.
marcio
323
"I have the Enermax EG451P-VE and the word "whisper" should not be associated with this thing. It is definitely not what I would consider quiet."
And they are not. The EG451P-VE is not from Enermax's "whisper" series. The EG351P-VE(FC), on the other hand, should be "whisper" quiet.
Sugadaddy
Banned
May 12, 2000
6,495
I have a regular Enermax 350, and it's actually not too loud.(better than my old Aopen that came with my case)
The whisper series should be really quiet...
