Originally posted by: swtethan
SilenX iXtrema 80mm 14dBA Case Fan
Fan Dimensions: 80 x 80 x 25mm
Fan Input: 12V/1.0W
Fan Speed: 1900 RPM +/- 15%
Air Flow: 28 CFM
Noise Level: 14 dBA
Connectors: Three Pin Connector, Four Pin Connector
theres even a 21cfm fan that does 11db
Originally posted by: Bluefront
Everything SilentX says about the db ratings of all their fans is a lie. There is no standard for db rating fans, universally used. So when they measure their fans with a microphone across the street.....wow 14 db.....maybe they do sound quiet.
Don't use mfg specs concerning noise levels when you consider fans. Almost everybody lies. SilentX is the worst offender.
I'd like to see a link to SPCR where they call SilentX fans "the quietest".
Me? I'm a big supporter of Yate Loon (Nexus) fans.....in most tests they come out #1.
Originally posted by: Shadowknight
I have an 80mm I haven't tested yet. I put it in the VGA duct for my P180, but it won't fit due to the placement of my CPU on the motherboard, as well as the size of my heatsink.
Okay, I'm a long time member of SPCR, and I registered just to correct JBDan here. The link he is referring to is a list of retired PSUs. Models that are no longer available, generally. Notice that at the end of each description is the date of the review. The SilenX review was back in June of 2003. There's a comment from April indicating that due to the length of time since the review, things may or may not be the same, so the review might not even apply to that particular model. Moreover, the noise rating (N) indicates on a scale of 1-10 how quiet a PSU is. A 10 is completely silent. As yet, NO passive PSU has received a 10. The highest rating was for a passive Silverstone that received a 9 (on the previous review page, page 6).
The Silenx received a 3.
For the most part SPCR mostly sticks with 120mm fans nowadays, so there's generally not any talk about the quietest 80mm fans. At last check, the Panaflo L1A was still the reference. Nexus has a good track record with their 92mm and 120mm. I have an 80mm I haven't tested yet. I put it in the VGA duct for my P180, but it won't fit due to the placement of my CPU on the motherboard, as well as the size of my heatsink. If you like, I can post an opinion on it tomorrow.
To my knowledge, Nexus is the only fan company that is known to report accurate dbs on their fans. The official testing method requires placing the fan in an anecrobic chamber (oh, I can't spell it) and mesuring the sound at 1 meter, the same distance used by SPCR in testing equipment for their reviews. Note that Nexus doesn't make the fans. they buy fans from other manufacturers, cherry pick the ones with the least vibrations and bearing noise, then apply an in-line resistor to slow it down (ex: rebadged Yate Loons at 1300rpm slowed down to 1000rpm). Still, they DO test their fans for noise in the official standards for determining fan noise, something the vast majority of fan makers don't do.
Also, there's a long thread on the dishonest marketing methods of SilenX: http://forums.silentpcreview.com/viewtopic.php?t=4504 Given their blantantly exagerrated specs, as well as the ethics of the owner, I will never do business with them.
It WAS the quietest 80mm fan... in the 2003 article. Generally, they're not going to update old reviews, because they're just that. Old reviews. The SilenX are actually rebadged ADDA fans with a big markup. If you can find out the appropriate model number, you can get the same fan for far less. Panaflos still tend to be the reference fan, though the overall quality seems to have dropped since they shifted manufacturing from Japan to China. Looking at the recommended fan page I found this quote in regards to the 80mm Nexus: "At 12V, the smoothest and quietest 80mm fan I've heard, better than the best Panaflo samples". Anyway, I have to admit I haven't actually heard a SilenX fan in person. I've heard mixed things on SPCR (even ignoring their reputation for dishonesty). I spent an hour searching, but I can't find anyone who's had experience with an 80mm Nexus vs. SilenX. I'm pretty sure the site owner isn't going to spend any money to purchase SilenX products for review, and that SilenX isn't going to ever send anymore review samples. Short of someone donating equpment for review, there's really no way to know for certain how SilenX compares to other products. I've heard that their 120mms don't compare that well to other SPCR favorites, though I've heard good things about their 40mm fans.
You're right that slower fans = less air = less noise. I read somewhere that the SilenX PSU is the quietest at idle, but gets significantly louder when it ramps up, that probably explains why it only gets a rating of 3.
Anyway, didn't mean to come off as hostile, it's just that SPCR members (such as myself) tend to hold a grudge against SilenX due to their tactics on the forums, as well as the history Peter Kim has in trying to screw his old bosses.
Wwith the exception of the Nexus company, I don't know of ANY fan companies that post accurate specs. Either it's because they're not following the established standards for the industry, or it's because marketing makes up numbers for their products (claim higher cfm and lower noise than in reality).
I did a quick search and here's some threads on opinions of SilenX fans and the quieter 80mms in general.
http://forums.silentpcreview.com/viewto...hp?t=19271&highlight=quietest+80mm+fan
http://forums.silentpcreview.com/viewto...hp?t=21858&highlight=quietest+80mm+fan
