Quietest 40 mm and 60 mm fans
alexruiz
2,836
556
Well, I hate the chipset fan and the video card fan, so I want to replace them. I have seen the crystal orb and other, but I was thinking about modding some 40/60 mm fans to make them rum. Also, the 7 volts trick is not a bad idea..... ;)
Do you know of any quiet 40 mm/60 m fan???
Thanks
zod
825
I'm running an old Slot-A Athlon with two 60mm low noise Adda fans which are pretty quiet. They only push around 13.2 cfm each, but are very quiet.
Acts837
1,072
I have a Vantec Stealth 60mm. It's not loud if I use 7 volts on it. Full 12 volts and it has a mild pitch a little louder than an L1A Panaflo. I have been wanting to buy a 60mm Panaflo but can't justify spending more $$ on another fan.
BA
5,004
If you ask me(and you did) 40mm aren't worth the trouble. They hardly move any air. You're better off with a larger heatsink and no fan.
In 60mm, there are some very quiet ones from Adda, Papst, and Sanyo-Denki, but I don't remember any model #'s off the top of my head.
keyeye
107
I've tried several 60mm fans to use on an PAL6035 for a 1.3ghz Celeron (.13).
1. The one that I settled on is a Panalfo L1Bx 60x25mm that I bought from Digikey. At 1200-1300 RPM with a fanmate1, it is silent. It normally runs at 3200RPM. It comes untailed, but you can buy the crimp connectors for the 3pin MB header (under molex). It's 10bucks for the fan, but if you send them a check and the order is over 25, you don't pay shipping.
2. I've tried a 60x25mm Sanyo Denki M402 (2800 RPM, but no speed sensor). It seemed quieter than the panalfo at rated RPM (though it is supposed to run slower anyway), but the motor noise was more at low voltage (via fanmate). I got it from allelectronics, but they are OOS now.
3. I have a delta 60x10mm slim (4800 RPM). When it gets less than 2700 RPM via fanmate it is very quiet (low motor noise). I was actually pretty impressed with it. This fan came off of a genericish coolermaster. Actually, I use this on a micro-fin aluminum heatsink.
4. Sunon 60x25mm (4200-4300). Decently quiet, but not in the above league. Found almost everywhere.
I haven't tried a stealth or adda. Papst, I haven't found at 60mm except at digikey, and it wasn't a low speed model.
I highly recommend the fanmate or 7V trick. Sometimes it can really get rid of annoying motor noise (at the expense of CFM, of course). Depending on your perspective (e.g. the rest of the system) it maybe all that it takes. The stuff that I talk about above may be completely irrelevant, depending on the computer.
As far as the actual task at hand, I recommend that you ditch the chipset/video fan for passive cooling if possible. I also hated the crystal orb, even if undervolted.
