SunTzuTech
I've got a Soyo Dragon Plus V1.0 with a AMD Mobile 2600+ running at 10x200Mhz,
and my temps on a generic aluminum HS with a fairly noisy fan are about 50C. I
also have some copper heatsinks that have a kingwin 70mm 5500 RPM fan that
is even louder than that.
I didn't really notice how loud it was til I started swapping all the case fans I had with
some panaflo L1-A's, in 3 of the PC's in the office.
Can anyone suggest a relatively good solution? Panaflo doesn't sell 70MM fans, and
the only place I found that have 70mm-80mm converters are out of them. I'd like to
reuse the copper heatsink, especially someone has a suggestion for a 70mm fan that is
as quiet as a panaflo or has got a stash of 70mm-80mm converters.
