- Jul 22, 2000
- 4,694
- 0
- 0
I got fed up with the ~20" standing fan I had because even the lowest setting was pretty loud, so I decided to give tower fans a go.
I just got this one from a local store: http://www.amazon.com/Bionaire...&qid=1251666970&sr=1-7
3 settings, the lowest one gives sufficient airflow. The general noise is ok, but there's a NASTY high pitched whine that the motor gives off, so I'm 99% sure I'm going to return it. I'm trying to find a decent (can be large), quiet fan. I don't need a lot of airflow, just something ... but needs to be quiet. If this fan was a tad quieter and didn't have the high pitched whine it would be perfect.
My ceiling isn't wired for a fan and I don't want to spend that much money to get it wired, so I'm limited to standing fans. It needs to be a standing unit.
Any suggestions? Do they even exist? Sadly NO ONE presents noise ratings on their fans, which is just stupid. It's like buying a car not knowing what the engine is.
