At newegg this totals out to ~$1048 shipped. I'd like to keep the total at or under $1k if possible. Trying to go with a quality PSU, quietly cooled parts, and no interest in SLI or anything else crazy/expensive.
I have a case I plan to reuse, and in my current system I have 1GB (2x512MB) of Kingston pc3200 DDR400 184pin ram I think i can carry over from my current system (A7N8X Deluxe 2.0 board) to the new Socket-939 board (please let me know if that's not true).
I want to upgrade my CPU and GPU, and, although it might look like I'm building a system to overclock, my actual goal is to run a quieter system by using a 3rd party cooler on the CPU that will keep it cooler and quieter and allow me to remove a case fan, and swap the remaining case fan with an L-1A Panaflo.
Bolded parts are updates due to your responses below!
Board: DFI LANPARTY UT nF4 Ultra-D - Retail
CPU: AMD Athlon 64 3200+ Venice - Retail
HSF for CPU: Thermalright XP90C over ZALMAN CNPS7700-CU - Retail
Fan for HSF: Panasonic FBL09A12M-1A 92mm Fan (from Coolerguys.com or other site - newegg does not sell 92mm Panaflos)
HD: Western Digital Raptor WD740GDRTL 74GB - Retail
Adding some form of vibration isolation to harddrive.
PowerSupply: SEASONIC S12-500 ATX12V 500W PS - Retail over Antec TRUEPOWERII TPII-480 ATX12V 480W PS - Retail
GPU: SAPPHIRE 100105U Radeon X800XL PCI-E Ultimate Edition - Retail (Review says it runs cool and very quiet compared to reference design).
Anything I should switch for another part? Anything left out that would help make my system quieter without adding lots of heat? (Gigabyte has an X800XL that is passively cooled but it's a friggin' OVEN of heat so I'm going with the quietest actively cooled X800XL.)
Should I go with a motherboard that doesn't have any active cooling fans on it? I believe the DFI LanParty boards have a fan on the northbridge which might add noise?
Thanks.
Thanks.
