Quiet Power Supplies
Aug 27, 2002
10,043
Originally posted by: PorBleemo
Originally posted by: lobadobadingdong
wierd, looks just like the forton 120mm psu's.
Wow. Makes me wonder if I could pop a reall quiet fan in there...
I can't hear my forton at all, probably the same fan, but the fortron has a rheostat on the back to adjust the fan speed as needed.
InlineFive
9,599
Mine too. But if you get too paranoid... :p
Zap
22,377
7
Originally posted by: TheCause
Has anyone seen a TTGI SuperFlower up close? I'm considering getting one.
I got two of the "dual fan ultra quiet" units, supposed to be 120mm fan units. They have a button on the back for fan speed, LOW/HIGH/AUTO. I also jumped in on the deal for $15 from Directron for the 140mm fan units. Just ordered last night and AFAIK hasn't shipped yet. The ones I've got/am getting are the plain Jane units, not the fancy mirrored ones.
Treyshadow
937
I have the 120 mm 450 watt TTGI in my old case. The case is also a superflower. Quiet yes, but the rails are not exactly 12v 5v or 3.3v like some other power supplies. My 12v on a P4 3.2c is running at 11.85v, while the others are almost perfect. My OCZ on an athlon 64 3400+ has adjustable rails, and without adjustment is just above the standard voltage for each rail.
I do like the button on the back of the Directron/TTGI to switch between hi-med-lo.
mdcrab
2,105
Received Silverstone PS today, one day early as Fed Ex SuperSaver usually does from Newegg.
I was having problems with system not booting Technical Support thread
Hooked up new PS, haven't checked voltages, but it is one nice & quiet PS. System booted right up. Now all I can hear are the case fans and they're Vantec Stealths & Panaflo FB08A12L's.
Contrary to some of the reports, this PS has plenty of connectors. Approximately the same as the Enermax EG365P-VE PS that it replaced. I was kind of skeptacle of replacing the Enermax as it tested OK, but I guess you can't trust those PS testers. They probably test voltages at low load conditions. If it tests bad it probably is, but if it tests good it may still be bad.
It is nice to have my main system back up and running.
One question regarding the PS. It has a three pin fan connector (with 2 wires). I am pretty sure it is for PS fan speed sensing, but what will it do if I plug it into one of the mobo fan headers?
mdcrab
mdcrab
2,105
Voltages from Soltek HM v 2.04
11.734
-11.97
-4.89
4.96
3.264
5.134
bat 1.508
12v seems low but I am running 4 80mm case fans plus cold cathodes. Not sure if this is a problem, but everything seem to be running fine.
