- Oct 18, 2012
- 9
- 0
- 66
I have a Corsair 550D with an H100 mounted on the top. The stock fans were kind of loud so I replaced them with Enermax T.B Silence fans. Subsequently reading this forum it seems that they might not have enough static pressure to be a good choice. I am thinking that I can use the Enermax fans to replace the case fans in the front and find a more suitable alternative for the radiator.
The Gentle Typhoons seem to be the fan of choice but I am having some difficulty finding them, I am also not sure which ones I should get. Two questions, can someone recommend specific GT fans for the H100, and the best place to buy them?
Thanks!
-gl
Thanks!
-gl
